W223 MBUX Error
  • Thread starterdylandy
dylandy
Can anyone help me fix MBUX on Mercedes-Benz W223 S-Class?
I am ready to pay.
It was an anti-theft problem. After the programming failure, the device cannot be connected.
Anti-Theft Protection
MBUX cannot be entered
Reactions:tchello777
This problem should be fixed by an official MB dealer.
I couldn't do it, but the dealer fixed it. Maybe someone here knows another way.
If you have the PIN code (if it is an OEM radio), you can unlock it again via DTS Monaco.
What kind of screen is this? The W223 has a 12.3-inch portrait screen.
The anti-theft PIN number is printed on the rear panel of MBUX. If you can remove MBUX and find the anti-theft PIN. Enter the engineering secret mode of Mercedes MBUX and try to reset the anti-theft protection using the PIN code.
The problem with XENTRY is common if your VCI can only work with CAN or DOIP. To access the MBUX advanced diagnostics in XENTRY, you will need a VCI that can work with both CAN and DOIP, while the MBUX unit supports DOIP.
You will need to enter the anti-theft PIN code. If you do this with XENTRY, you will need to reflash the entire head unit (if an update is available online), but otherwise you will be able to activate it in DTS Monaco without reflashing the device.
Handed3219
Handed3219
Handed3219
stevejia
  • stevejia
wojciech300
percooo
  • percooo
wojciech300
