X167 Change Language
  • Thread starteradamg588
adamg588
I am a newbie and want to change the language on GLS X167 2020 in DTS Monaco, with which module can I find this option? HU5? I also have Mercedes Multibeam headlights and want to change the coding from US to EU.
You can change the language without coding. Press the car button near the touchpad and select car settings.
Multibeam requires HLI, PXL, EZS coding. When changing the coding to PXL, it is necessary to reactivate it using the routine in DTS Monaco.
I tried to change the language but I couldn't find my language in the list.
HLI, PXL, EZS, HU6 coding.
HU6 - done.
I have a problem with PXL and HLI coding, I changed the lamps, both are broken, but the electronic module is from this car. The left one works, but the right one has an error, I tried to find out with Xentry, but it does not work... I am looking for what I should do in DTS Monaco. Do I need to code PXL or HLI first?
EZS - just for firewall, or do I need to do something else?
  • tom123
wszop
  • adamg588
adamg588
  • pepeuszz
benidenesene67
