XENTRY Diagnostics OpenShell and Pass Thru v06.2024
  •  Download
Moderator
Staff member
Developer
XENTRY.Diagnostics.OpenShell.And.Pass.Thru.v06.2024.01
XENTRY.Diagnostics.OpenShell.And.Pass.Thru.v06.2024.02
XENTRY.Diagnostics.OpenShell.And.Pass.Thru.v06.2024.03
XENTRY XDPAD/XDPAD2 backgrounds (archive attached for download):
XDPAD.Background XDPAD2.Background
What's new in XENTRY v24.6.4 from 06.2024:
  • TIPS documents are now directly available in the quick test
  • Added several new vehicles for future use
After a quick test has been run, the relevant TIPS documents for the fault codes that are present are now determined automatically.
Select one of the displayed fault codes with a TIPS icon.
Note: The TIPS icon indicates whether one or more TIPS documents have been found for a given fault code. This information can also be found in the control unit and the main group.
Select "Open TIPS document".
  • After the release of 12.2023 SDconnect/C4 was officially disabled (it is possible to enable it back)
  • Offline login named XENTRY has been disabled since 03.2024 version
System changes:
  • The OpenJDK runtime has been updated from build 11.0.16.1+1-LTS to 11.0.22+7-LTS
  • Another XENTRY service they had been working on for almost 2 years was removed from the system
  • Many improvements/fixes in the interface and changes/additions to the structure of configuration files
As a result, this version of XENTRY should be faster than the previous one.
XENTRY download links are attached.
OS: MS Windows 10 and above
Installed size: 41.80 GB
  • XENTRY.Diagnostics.OpenShell.v06.2024.zip
  • XENTRY.Pass.Thru.v06.2024.zip
  • XENTRY.Backgrounds.v06.2024.rar
  • Love
Reactions:avecesveobugs, dobro, icostel09 and 88 others
  • XENTRY Diagnostics
