User
Member
- 98
These are my first questions after the introductory post.
My future car will be a V-Class W447 MOPF2 2024. As far as I know, it will be a DOIP only car, right?
After much reading and research I came to the conclusion that I need the following:
Is this correct? Does this fit?
I read that on new cars, for example on the 2021/2022 Vito, reading the data is difficult or even impossible. Could it be that it no longer works offline and requires an online connection? Can I read my new car myself using the above products? First of all, I just want to be able to read and delete errors and adjust configurations if necessary through Xentry if possible.
Since the car has almost everything, I can only think of two things that could be coded:
Do I need DTS Monaco or Vediamo for this?
Thank you very much for your help.
- Xentry OpenShell 3.2024 or 6.2024 for MOPF2 2024 vehicles
- Xentry Fix for offline use
- ZenZefi valid certificate
- VXDIAG VCX SE for Mercedes-Benz
- Start/Stop Last Mode (or can this be done through Xentry?)
- Unlocking an Augmented Reality Camera as a dashcam (currently only available for order in Switzerland)
