XENTRY with ENET Cable
  • Thread starterjdl1102
jdl1102
What is the latest version of Xentry (not XPT) that can work with ENET cable?
Reactions:zuzuhe
  • S
    Given by sirius
There seems to be no correlation between the cable and the diagnostic version.
I don't know if Xentry works with ENET cable, but you can certainly configure DTS Monaco with ENET to allow DOIP programming.
There was an old version that worked with ENET cable. But I want to use the latest version of XDOS.
Reactions:39fb29dndf
Version 06.2023 worked for me. Use a static IP for this. Makes life easier.
Reactions:jdl1102
Would you recommend any of these cables? I mean, I have an Openport, but from the way you talk, it seems like it would be better if I got one of these cables, right?
XDOS version is also available but requires a small program.
ENET DOIP is only applicable to newer W206, W223, W232, W214, W254 cars.
Reactions:NIMAR, Turonet, JanNeu and 3 others
If you're going to copy someone else's work, can't you at least do it well?
Reactions:NIMAR, Turonet and IKY786
I tried 03.2024 XDOS Xentry with ENET cable but it didn't work. Does anyone know how to do this?
I tried 03.2024 XDOS with ENET cable, everything works fine.
You can try to switch to XPT by changing registry.
  • dannyb13
Fotom
  • kenaj23
Rade1978
Rade1978
  • theslydog007
Daniulis
