XENTRY XPT Error Loading Control Table and CNT File
  • Thread starterdavinci
davinci
I have a Xentry XPT with Scanmatik PRO and when I connect it to a Mercedes Actros MP3 model truck I get "error loading control table" and "error loading CNT file".
How to solve this problem?
petr78rus
  • petr78rus
    Given by petr78rus
Scanmatik works with vehicles via CAN bus, that is, via Xentry. And your ten-year-old vehicle is diagnosed via DAS, again, either change the software or the device.
What software do you recommend for both trucks (Actros MP3/MP4) and which one is compatible with Scanmatik?
I don't want to offend you in any way, but if you only have Scanmatik (probably a Chinese clone) for diagnostics, then you don't need to do this at all. Scanmatik is not intended for full-fledged work and diagnostics with Mercedes. If you want to work properly, buy equipment for different software, such as XDOS, XPT, XDPAD, DTPID, DTDPT.
I think so too, the best option is Xentry 2023/09 OpenShell (including trucks) and VCX or C6 or C4.
I have Xentry XPT running without any issues with SM2Pro. Check the firmware version on the device sticker and use official drivers for this feature. If the official SM program doesn't connect, XPT won't connect either. I'm telling you this so you don't go crazy with XPT. Connect your car to official SM2Pro first, then try with XPT.
Thank you for your answers.
My SM2Pro connects perfectly to other truck models such as the Actros MP4 and I can run diagnostics and work with XPT.
But when I connect XPT to an older model like MP3, I get "error loading control table" and "error loading CNT file".
The connection problem with the Mercedes Actros MP3 is caused by the incompatibility of the XPT with older trucks such as the MP3. XENTRY Pass Thru (XPT) is not compatible with LKW DAS. The XPT is missing the DAS LKW folder, which causes "error loading control table" and "error loading CNT file" issues for these models. Given this limitation, I have looked into other options such as Xentry 2023/09 OpenShell or SDconnect to diagnose your trucks.
Now I understand why it doesn't work. One more question.
Is XENTRY OpenShell 09.2023 compatible with Scanmatik 2 PRO? Or will I have to buy another one? Which one do you recommend?
Reactions:Rade1978
No, that's why I'm writing to you, so that you buy another multiplexer.
Scanmatik PRO is not compatible with OpenShell. Only VCI, MB SDconnect, C4 or C5 are compatible with this version of Xentry. For better support for both models, consider the MB SDconnect, C4 or C5. These tools are designed for the latest Xentry OpenShell 2023/09 release and offer extensive diagnostic and programming capabilities. Additionally, the C4 is compatible with MP3 and MP4 truck models, providing comprehensive diagnostic coverage and functionality.
Reactions:Rade1978
Buddy, how many times do you have to repeat this before you get it?
  • PeteM123
PeteM123
  • GeorgeF
GeorgeF
blueabyss
  • blueabyss
blueabyss
blueabyss
