308 1.6 DPF Fluid
  • Thread starterwatson83
watson83
watson83
When I start the engine the service light comes on and there is a warning about low DPF. I have called Peugeot but they want to charge £160 for diagnostics before doing anything. Is it as simple as topping up the fluid? Will I need diagnostics/software to reset the lights/warning?
Reactions:Katja1984
What is an error message on the display? The level of additive tank is not measured, it is calculated ECU. After refueling, this should be programmed to the control unit. I recommend Diagbox as software.
Reactions:sxjose20001 and Tomasc1
iiXCoNsT3rXii
crypt0ninja
Tsunami41
rimedre
rimedre
rimedre
