X
xzoommer987
I have VCDS and I tried to program the automatic trunk closing with the key fob, but I couldn't find any adaptation to activate this function. I've seen other cars of my model do this, so I'm surprised that mine can't do it.
Below are the channels I can switch between, but none of them are linked to closing the trunk with the key fob:
- IDE04194-ENG116634-Activation using rear lid opening button in remote key-Touch function for opening -> active
- IDE04194-ENG116635-Activation using rear lid opening button in remote key-Tap function for closing -> not active
- IDE04194-ENG130229-Closing with remote unlock button 2 of rear lid when using trailer -> not active
- IDE04194-ENG130228-Opening with button 2 for remote unlocking of rear lid -> not active
- IDE04194-ENG125917-Opening with button for remote unlocking of rear lid -> not active
- IDE04194-ENG116633-Remote control: closing with button for tailgate unlock mechanism -> not active
- IDE04194-ENG116632-Remote control: opening with button for tailgate unlock mechanism -> not active
- IDE04194-ENG116630-Sensor for rear lid opening -> active
- IDE04194-ENG116631-Using sensor to close tailgate -> not active
- IDE04194-ENG122707-Using sensor to open tailgate -> not active
- IDE04194-ENG116629-Using button to close lock mechanism in tailgate handle -> active
- IDE04194-ENG116628-Release button in rear lid handle -> active
- IDE04194-ENG116627-Rear lid lock button in luggage compartment -> active
- IDE04194-ENG125916-Button for opening rear lid in luggage compartment -> active
- IDE04194-Deactivation of tailgate -> active
- IDE04194-Program opening stop -> 1521
- IDE04194-Detection area upper -> 20
- IDE04194-Offset for maximum programmable opening stop -> 5
- IDE04194-Reverse path when opening -> 0
- IDE04194-Reverse path when closing -> 100
- IDE04194-Minimum opening height of tailgate -> 300
- IDE04194-Offset for opening height after basic setting -> 0
- IDE04194-Opening height in production mode -> 60 %
- IDE04194-Deactivation of luggage compartment cover -> not active
- IDE04194-Luggage compartment cover: tolerance of block counter -> 20
