I need help with updating the control unit of a W204 2008 pre-facelift to facelift. So far I have only been able to do this with a programmer for reading/writing EEPROM.
1. Made a backup copy of the instrument cluster EEPROM.
2. Copied kilometers/miles.
3. Copied the SSID.
4. Activated the AMG menu.
I reflashed the EEPROM on the new cluster, everything went well, but I'm stuck, many functions are inactive.
1. No fuel level indication in the tank (fuel gauge is faulty).
2. No fuel consumption/engine power indication.
You need to keep the original EEPROM and change the SSID, enter 0 mileage to synchronize with EZS, and then enter the AMG menu code. In units with different part numbers, the EEPROM is very different.
I saved a copy of the original EEPROM from the old monochrome cluster, and also a copy of the EEPROM from the new color cluster.
I need help with the EEPROM BIM file to make it virgin.
