Daimler Truck Diagnostics Platform Independent and Pass-Through v01.2025
  •  Download
Moderator
Staff member
Developer
Daimler.Truck.Diagnostics.Platform.Independent.And.Pass-Through.v01.2025.01
Daimler.Truck.Diagnostics.Platform.Independent.And.Pass-Through.v01.2025.02
Daimler.Truck.Diagnostics.Platform.Independent.And.Pass-Through.v01.2025.03
Daimler.Truck.Diagnostics.Platform.Independent.And.Pass-Through.v01.2025.04
KIT3/KIT4 backgrounds (archive attached):
DTXDKIT3.v01.2025.Background DTXDKIT4.v01.2025.Background
New monitoring service added.
WIS/ASRA Standalone no longer makes sense to integrate into XENTRY and DAS due to a large number of system changes, much the same happened with the XDOS and XPT versions.
C4/SDconnect is fully functional in the commercial activation.
The final versions are available for download.
DTPID 25.1.4 (Daimler Truck Platform Independent Diagnostics).
DTDPT 25.1.3 (Daimler Truck Diagnostics Pass-Through).
OS: MS Windows 10 and above
Installed size: 32.60 GB
  • Daimler.Truck.Platform.Independent.Diagnostics.v01.2025.zip
  • Daimler.Truck.Diagnostics.Pass-Through.v01.2025.zip
  • Daimler.Truck.Backgrounds.v01.2025.rar
  • Love
Reactions:jomarht, Maxtester, luki03 and 14 others
In this version, when selecting industrial units - Kamaz, the activation tab has disappeared.
What is the reason, what has changed in this version?
98B7502
Probably a problem with the license key algorithm. To be honest, not many people work on these particular cars. I would assume it is not a priority task due to the current situation. A license key allows you to use special features that are not normally available, such as "developer" features. I will say it's impressive that this was released. So give the developers some time and I'm sure they'll be able to fix it for you.
ahmedmph
ahmedmph
