Daimler Truck WIS ASRA Standalone v07.2021
  •  Activation Download
Moderator
Staff member
Developer
Daimler.Truck.WIS.ASRA.Standalone.v07.2021_autogmt.com.01
Daimler.Truck.WIS.ASRA.Standalone.v07.2021_autogmt.com.02
Daimler.Truck.WIS.ASRA.Standalone.v07.2021_autogmt.com.03 Daimler.Truck.WIS.ASRA.Standalone.v07.2021_autogmt.com.04 Daimler.Truck.WIS.ASRA.Standalone.v07.2021_autogmt.com.05
Some members asked me to make WIS Standalone compatible with DT system.
I do not see the point in removing cars, smarts, transporters and etc. from it, so the functionality is absolutely the same as in my standard version for XDOS and XPT but for DTPID and DTDPT systems.
The Daimler Truck Diagnostics program must be installed in the DEFAULT directory (C:\Program Files (x86)\Daimler-Truck).
WIS Standalone will be installed in this folder and linked to XENTRY and DAS.
It is fully activated and ready to go, you do not need to modify anything.
Everything else is as in this description:
Daimler Truck Platform Independent Diagnostics or Daimler Truck Diagnostics Pass-Through version: v12.2023 to v10.2024
OS: MS Windows 7 and above
Installed size: 16.71 GB
  • Daimler.Truck.WIS.ASRA.Standalone.v07.2021_autogmt.com.rar
  • Daimler.Truck.WIS.ASRA.Standalone.v07.2021.Update_autogmt.com.rar
Reactions:kamelmdk, scorpion4x4, Camber53 and 27 others
DAS and XENTRY integration does not work since version 01.2015 and many changes need to be made to restore it. If after AddOns the entire chain of modified files is broken, the system will simply stop working.
Reactions:Real
