HERMES Emergency Call System Manual (Technical Description)
  • Thread starterjysi
jysi
HERMES 2.0, 2,1 (2018) Manual_HERMES 20-mod_20180508 - 3871855.pdf - Contains system connector pinout, etc.
Older versions:
HERMES 1.5 (2022) Manual_HERMES1-5-mod_220801 - 6061697.pdf - Minor differences (WLAN+BT chipset, etc.), otherwise the same document as 2.0/2.1 version.
HERMES 1 (2015) Manual_Hermes-DRAFT_1505xx rev02 - 2785889.pdf - In practice the same hardware as in version 1.5, but the document is not as detailed.
  • 3871855.pdf
  • 6061697.pdf
  • 2785889.pdf
Reactions:Ruckmess, geo12, c250 and 4 others
Thanks jysi.
The Mercedes part number appears to match the Hermes version.
All of them can support GSM (2G), UMTS (3G) or LTE (4G), depending on the destination market.
Hermes 1.0 - A213 90x xx xx
Hermes 1.5 - A222 90x xx xx
Hermes 2.0 - A177 90x xx xx
Hermes 2.1 - A247 90x xx xx
Reactions:jysi
An example of a Hermes 1.0 inside with a green USB connector going to the multimedia unit. In this case, data transfer between the multimedia unit and Hermes is carried out via USB. Often found when entry head unit is built in (code 522 for W213 E-Class).
Another type of communication is via WLAN (Comand Online or Audio 20 with code 531 or 506 for W213 E-Class).
Reactions:jysi
Ok, with this guide, is it possible to change the country so that Hermes can call emergency services in another country, or is it not possible? I am looking for information on how to do this in Xentry. Thank you.
I know this is an old question, but Xentry has a feature that allows you to change it without any code.
I have already managed to change it, with Xentry 12.2023 all that remains is to select the country, anyway thank you very much.
