If you are using CLIP software, you will receive an error message: "The vehicle is not subject to diagnosis with the CLIP device, please switch to the ADT device."
Renault Group has launched the Alliance Diagnosis Tool (ADT) across its dealer network worldwide. ADT is the next generation of diagnostic and repair tool for vehicles manufactured after 2020.
VXDIAG VCX NANO does not work via DOIP and cannot be used as a transit communication channel with the ADT, the Renault program.
VXDIAG VCX SE works via DOIP, but some users tested it and found that they could not use physical token for ADT.
Therefore, for new Renault cars with the SGW security gateway, it is better to use the original VCI or Autel/Launch X431 scanners (you will...
