ISTA-P Problem
  • Thread starterDragomirMPower
DragomirMPower
I have a problem with ISTA-P, ISTA+ works but ISTA-P does not work, error 94025 detection of control modules in the vehicle failed. Please help. I use OEM ICOM Next.
ACKID
  • ACKID
    Given by ACKID
Error code 94025 in ISTA-P typically indicates an issue with communication between the ICOM Next diagnostic tool and the vehicle's control modules. Here are some steps you can take to troubleshoot and potentially resolve the issue:
Check Hardware Connections:
Ensure that all cables are securely connected between the ICOM Next interface, the vehicle's OBD2 port, and the computer running ISTA-P. Sometimes loose connections can cause communication errors.
Restart ISTA-P and Computer:
Close ISTA-P and restart both the ISTA-P software and your computer. Sometimes, simply restarting the software and system can resolve temporary glitches.
Check Vehicle Battery Voltage:
Low voltage in the vehicle's battery can sometimes cause...
Low voltage in the vehicle's battery can sometimes cause communication issues. Make sure the vehicle's battery is fully charged and in good condition.
Check ISTA-P Version:
Ensure that you are using the latest version of ISTA-P software. Updating to the latest version may resolve compatibility issues and bugs.
Check Vehicle Compatibility:
Make sure that the vehicle you are trying to diagnose is supported by the version of ISTA-P you are using. Some older vehicles may require specific software versions.
Check Network Settings:
Ensure that the network settings on your computer are configured correctly to communicate with the ICOM Next device. Sometimes, firewall or network settings can block communication.
Check for Interference:
Ensure that there are no other diagnostic tools or electronic devices connected to the vehicle that may be interfering with communication.
  • Reniu12
Reniu12
  • jimk
osaman1999
osaman1999
  • Gew77
jon
