Map and System Update NTG 2.5
  •  Download
  • Thread starterkristihabilaj
kristihabilaj
Has anyone encountered the problem that NTG 2.5 does not work correctly?
If anyone can help with the software update 09.29 and the map of Europe W164 2009.
Reactions:kmafus
I'm posting a way to update NTG 2.5 to the latest firmware 09/29 using a SD card. This is very convenient when the DVD drive does not work.
Manual... I have already replaced.
Here is the TELEMATICS CD ALL 05/12 (DVD-ROM) disc number A1718274559 + instructions.
Open the ALPINE_DVD folder.
Open the CD_INFO.CDI file using Notepad, replace the number 2518705094 with the HW number of your Comand, save, close.
Open the CONFIG.CDI file using Notepad, replace the number 2518705094 in four lines with the HW number of your Comand, save, close.
Write ALL CONTENTS of the ALPINE_DVD folder (with already corrected files) to the root of a blank disk or SD card previously formatted in FAT32 (which is accurately read by the Comand), with the obligatory condition that the volume label of the disk or memory card has the name ALPINE_DVD.
Insert the SD card or disk into the Comand after removing all the disks in it.
Enter the engineering menu by simultaneously pressing three buttons: hang up+6+*
Select Menu-SWDL-SW Update.
Launch the update and it will start and work completely automatically, wait until it finishes (not quickly).
Once the update is complete, the device will reboot. Now the SW version of your Comand is 09/29, now your Comand reads flash drives up to 32 GB.
  • ALPINE_DVD.rar
Reactions:ivomarchev, effect, atomantmk and 11 others
Where can I find the HW number and how long does it take to update it?
Reactions:gliscinski
You will find it there (HW).
The update takes about 20-30 minutes.
Reactions:edith, outcast7680 and gliscinski
Is this the current software?
I can no longer connect via Bluetooth to Mercedes ML W164 COMAND NTG 2.5 with any phone. Please let me know if an update is needed and how to do it.
  • eyprok
police21063
police21063
Filipov1912
  • sunxinda
  • Navigation
sunxinda
