Mercedes E220 W212 OM651 Won't Start
  • Thread starterkhiz
It's very possible. If the chain has slipped, you will have the same symptoms. The chain on the OM651 is short and usually lasts longer than the engine. What's the mileage?
The car has approximately 180,000 miles. Before replacing the tensioner, there was a constant knocking noise, but after that, the car ran fine.
The problem began with the car not starting immediately after turning it off. After 20-30 minutes of sitting, it would start with difficulty and run more or less normally, continuing until the next time it was turned off. Eventually, it wouldn't start at all.
The coolant and oil levels are normal, and the car has recently been serviced. No error codes were detected.
The car is currently parked 60 miles away, so I can't perform any further testing.
legis_clc180
  • legis_clc180
legis_clc180
legis_clc180
Dyostin23
Dyostin23
Dyostin23
  • Marketplace
2 3
43K
