Mercedes W212 136 HP Year 2013
  • Thread starterGeko
Geko
I did my first coding using Vediamo.
I would like to do another coding to disable Start/Stop and don't know what data to use.
Please help me.
Do you know what model 212 you have? You can usually find out by looking at the VIN number and finding out what engine and ECU versions are installed in your car.
Reactions:Geko
This is a 2013 Mercedes W212 with 136 hp.
You need to provide more data, such as CRD3, CR6, CR60LS...
Then we can help you. Usually one parameter changes.
Reactions:vautex
The W212 with 136 hp is an E200CDI with an OM651 engine. May have two types of engine control units: CDID2 or CDID3.
If it is CDID2, you can disable the Start/Stop function by changing the coding to "Stopp-Start Logic, Last Mode".
To determine which controller you have, use Xentry and check the engine control module identification. Then you can choose Vediamo or DTS Monaco.
Reactions:vautex
Thanks everyone for the reply. I would like to know which CBF tab to select for Start/Stop.
I tried to code the Start/Stop function. The tab I need is CRD3, but I can't access the ECU. I attached a photo. Please help me.
I tried to code Start/Stop and when I wanted to enter manual command via ECU I got three digit response instead of four, why?
I took two pictures.
lirimen
  • lirimen
lirimen
lirimen
  • Selectronic
cmkfarooque
  • Dervo90
Dervo90
