NTG 6.0 VIN Change Tool
  •  Tools Download
  • Thread starterhfelix1
hfelix1
Mercedes-Benz NTG 6.0 platform frame number modification tool.
operating menu
  • Mercedes-Benz Serial Tools.rar
Reactions:mercedesmods, umka, picf16 and 36 others
Nice, but what else is needed to use it?
Reactions:marky1991 and Ajkaro
Dear hfelix1, what device works with this tool?
How to use it in NTG, if possible please provide a short tutorial.
Reactions:marky1991
Platform boot emulator, TYPE-C connection between emulator and laptop.
Reactions:marky1991 and GTechimports
Thanks for your share, it would be great if you could tell us a little about the potential of this software, what it can be used for and how to use it.
Why do you want to change the VIN?
To work on the bench you need an emulator. Also you can update the navigation map if you change the VIN which has the map PIN, then you won't need the original HU map PIN.
How to connect UART on a PCB? In test points, what is each one on the HU6 PCB?
The software is simply a serial port console such as PUTTY or TeraTerm, without the correct commands it won't do anything special.
Reactions:r2p
Hello, can anyone tell us where we can get TXD and RXD for UART connection and more importantly what commands are used to change VIN? Thank you.
  • cmkfarooque
jdv91
  • gibsonlp
gibsonlp
  • Ollikola
cmkfarooque
