Retrofit of the 360 Surround View System NTG6
  • Thread starterpapayapokpok
papayapokpok
papayapokpok
Warnings
5 / 1
I need advice on the coding process for upgrading from a standard rear view camera (RVC) to a 360° Surround View System.
I have already completed the physical installation of the equipment, including mounting all four cameras and replacing the original camera control module with the correct unit compatible with the 360-degree view.
I am currently encountering the following integration issues:
The head unit (HU) display still shows the standard rear view camera interface instead of switching to 360° view mode.
The parking sensors (Parktronic) have stopped working and are currently inactive.
It appears that the vehicle's central gateway and associated modules are not yet configured to recognize the new hardware. Could someone provide the specific coding steps, parameters, or configuration codes (VO/SCN) that need to be modified to ensure the system operates and calibrates correctly?
Is a ZenZefi certificate or license required to perform the coding for this retrofit process? Or can this be done using standard coding methods (for example, manually via DTS Monaco /Vediamo)?
E200 C238 2021 HU6, VCI M6, DTS Monaco, XENTRY.
  • User
User
  • User
reddeuil
  • Filipov1912
pretrofit
