SDconnect C4 WiFi Connection
  • Thread starterpiotr167
piotr167
Is there a way to connect C4 to Windows 10? It does not have a WEP connection. Any solution?
Reactions:wolf38
Daimler
  • Daimler
    Given by Daimler
You can connect C4 WiFi in different ways.
If you have WiFi where you work, connect the C4 to the same WiFi network that your laptop is connected to in Workshop Mode. You can enable the hotspot on your laptop and then connect to it. Use Road24h. Do a YouTube search for "How to set up C4 DOIP WiFi connection" and you'll get plenty of tutorials.
You can connect C4 to WLAN.
The SSID from C4 is Road24h and the password is (26 x a).
You need to correct your IP address in the Windows network configuration to the correct network range, for example: (192.168.2.119).
Reactions:Eper
The main thing is to use the correct IP address and network mask on your laptop so that you can communicate with the device. It does not receive a DHCP address and the IP address is static. You must configure your laptop in the correct subnet range as C4.
  • Loomi
Baly
Baly
  • odaishisama
odaishisama
Ajkaro
  • Ajkaro
cmkfarooque
