The TCU Has Been Replaced
  • Thread starterUser
Full data cloning will resolve all issues reported by XENTRY, provided the transmission has no mechanical faults and the TCU was replaced only due to an internal fault in the old unit. AVDI customization also works, but after customization, you'll still need to flash the corresponding CFF file. If gear shifting isn't smooth, you'll need to adapt the shifting using XENTRY.
Your EEPROM is damaged. If you have a tool to read the EEPROM from the TCU, you can send it in for repair. After repair, write the data back to your TCU, perform the adaptation, and everything will be fine. Good luck!
Galina
  • Klovis7512
kenaj23
snow6852
  • snow6852
snow6852
snow6852
