Toyota and Lexus EWD 2004-2018
  • Thread starterdevildevil87
Lexus_EWD_2004-2018_HTML
Official electrical schematics for Lexus and Toyota vehicles for the European region.
1. Run install.cmd to extract the manuals (the extracted files take up 19 GB).
2. Run server.exe (port 80 is used by default, a different port can be specified in the server.ini file).
3. Open your browser and go to "hxxp://127.0.0.1" (if the port was changed, use the address "hxxp://127.0.0.1:XX").
Unfortunately, the server script sometimes freezes and needs to be restarted.
Find the Lexus logo in the system tray, right-click the icon, and select "Exit". After that, you can restart the server.
If anyone can suggest a more stable server version or knows what JavaScript fixes need to be made to work without the server, please send me a private message.
You can save disk space using the frspc.cmd file (reducing the size from 19 GB to 6.8 GB).
Running this file as an administrator initiates a standard compression procedure for the entire folder using the LZX algorithm.
NOTE! This method works only on drives using the NTFS file system. If files are copied or moved to another location (or drive), they will be decompressed and will need to be compressed again.
  • Toyota.And.Lexus.EWD.2004-2018.rar
  • smoke100
smoke100
pizdokleszczyk
  • pizdokleszczyk
pizdokleszczyk
pizdokleszczyk
