Hmm, can I ask why you want to do this instead of just buying a Plug'n'Play LED?
Your car is listed as Osram and Philips approved (which I would give anything for, since my car is not on that list).
I have a Passat B7 and my car is listed as Osram and Philips but I still replaced them with LED headlights with Xenon, they are plug and play headlights. After the replacement my low beam bulb failed so I had to install VCDS and code the LED headlights. It is best to replace standard halogen bulbs with xenon ones, since Xenon lamps are brighter than low-quality standard bulbs. It's time for companies to install Xenon on all cars.
