Vediamo Vehicle Restrictions
  •  Vediamo
  • Thread startervitimaautogmt
vitimaautogmt
Is there a year limit for Vediamo? I have a MB GLA 2020 and I want to customize something. Do you know if this is compatible?
  • H
    Given by hafsa
When working with Mercedes 2020+ cars, the best tool is DTS Monaco, for older cars you can use Vediamo.
If the Vediamo you are using has the correct CBF files, it will be able to communicate with the control units. It will also depend on what exactly you are trying to code. For example, some codings will require a Seed Key Calculator or an unlocked CBF file before you can code the AMG menu. But even without this, a lot can be changed.
Reactions:Bruto and maba41
Ajkaro
  • Ajkaro
cmkfarooque
  • kev159
mustafa666
rimedre
rimedre
