VGS3 NAG2 Clone
  • Thread startercarlosc
carlosc
I have a W204 220 CDI with TCM problems.
Can anyone help clone a used TCM using Vediamo?
Separately only for HW 0335457332 VGSNAG2_VGS2. Here is one. You need C4 and Vediamo 5. You can make it new and then flash it with the correct firmware and code it correctly.
1735459558927
Here I have VGS3 NAG2.
So can I clone it with Vediamo?
There is such a module in the car.
This is another used module.
Cloning is possible, but not with SD, only with an ECU programmer with a protocol for this VGS.
With SD you can update, flash and adapt to your car.
Which programmer do you think would be best suited for this task?
I'm trying to flash it using Vediamo, but haven't had much success.
I saw on the Internet that I need to unlock the ECU with command, then use search code to find the ASH code for boot mode, then flash the original file.
I do this but it does not start and some errors occur because I do not use SCN coding.
Can anyone help me do this correctly?
  • BUGBEAR
Skelebob9
localmode
  • localmode
Justinas10
Justinas10
  • andresz28
andresz28
