W203 TPMS/RDK, Information Not Displayed on Instrument Cluster
  • Thread starterBruto
Bruto
Bruto
Retrofitted everything as in the original from W209/W171, but in W203.
Control unit N88, which in DAS already shows pressure and temperature, but on the cluster still does not show anything even after several initializations.
I have a N88 control unit from an American W171 car and I am installing it in a European car. Could this be the problem?
I can't find the CFF update file yet.
The problem may be the lack of TPMS option in the EZS unit, as this is a 2004 version and only has TPLW (warnings via ESP).
Reactions:mabaragh
There was no need to update as this is already the latest version. When performing the remaining adjustments, there was no result for displaying pressures on the instrument cluster.
Although the TPC (TPMS) unit is recognized in the W209 simulation, in the W203 this unit is not recognized in the internal CAN network, and since there is no direct activation in the EZS, this will be the next task!
In EZS programming there are 64 options numbered 0 to 63 that correspond to specific units of measurement. How do I know what the units of measurement correspond to or what the purpose of these options are?
Code:
NWM-Sollkonfiguration: Gerät Nr. 0 - 63
NWM target configuration: Device No. 0 - 63
Control unit adaptations
Bruto
Bruto
Bruto
Dyostin23
Dyostin23
Dyostin23
  • Gummi
Gummi
