bergut
A 2010 W212 was delivered, smelling of gasoline. Diagnostics revealed no issues with the front and rear EVAP valves.
When activated, everything works, but when the car is started, the front valve does not work. I manually closed the rear tank valve and disconnected the connector. The problem is solved, but I need to troubleshoot because the fuel tank is bloating.
What could be the problem? Should I look in the coding or in the engine control unit?
