W213 IC HU Firmware Request
  • Thread startermaximusmx
maximusmx
Does anyone have firmware files for these HU and IC that can be shared?
I am very grateful for this.
ECU instrument cluster has the HW number: 2139017309, version: 17/03.00
ECU instrument cluster has the following SW numbers:
2229042901 16/30.00 valid 00-00-00
2229029616 17/26.00 valid 17-09-04
2229029814 16/48.00 valid 00-00-00
2229029914 16/48.00 valid 00-00-00
2229020015 16/48.00 valid 00-00-00
2229020115 16/48.00 valid 00-00-00
2229020215 16/48.00 valid 00-00-00
2229026315 17/07.00 valid 00-00-00
2229020415 16/48.00 valid 00-00-00
2229026415 17/07.00 valid 00-00-00
The head unit ECU has the HW number: 2139018310, version: 17/16.00
The head unit ECU has the following SW numbers:
2139042901 19/14.00 valid 21-07-13
2139023923 20/09.00 valid 21-07-13
2139022319 18/30.00 valid 19-09-25
2139029821 19/44.21 valid 21-07-13
2139037103 20/34.00 valid 21-07-13
2139037203 20/34.00 valid 21-07-13
2139038402 18/40.00 valid 21-07-13
The head unit ECU has the following serial number: MEG940K326P746
Reactions:Erdyasin58
The link to download the SW for the head unit is attached in a RAR file, its size is about 1.6 GB.
  • SMR-D.rar
Reactions:localmode, r2p, satmonster321 and 2 others
Is it possible for you to find firmware for my head unit?
HW: 2139016807/001 version 16/26.00
SW: 2139026216/001 version 17/40.01
I want to update the firmware of the head unit and maybe flash the special A238/C238 files to get the correct image of the car after replacing the head unit.
See my other post:
Sorry for the late reply. It weighs 1.6 GB. It should be replaced with a Coupe. It should replace the picture to the coupe.
  • 2139026216_001-ALL-20190602_1139.zip
  • Love
Reactions:r2p, Erdyasin58 and satmonster321
How to update MBUX (to FUP4) and instrument cluster of my W177? Is it possible to install this update using DTS Monaco?
My car is W177 A200 AMG line.
Yes, you can, if you know the SW update numbers. You can only update via any of the DOIP interfaces, otherwise you can kill your HU/IC.
Reactions:Erdyasin58 and rimedre
Can I flash firmware to my W177 car using DOIP ENET cable? Do I need to enter something like a password when installing the firmware to avoid an error?
You need to be sure that the files you are going to flash are perfect for your hardware. For example, there is a common problem with HU55: if your BL is not suitable, the DOIP inside the HU may fail and you will not be able to flash it anymore. Until you feel confident in flashing units and understand how everything works in Mercedes, do not flash units, only code.
  • maximusmx
samo
  • no2spam
PeteM123
  • Marketplace
