W213 Service Numbers
  • Thread starterZettl
Z
Zettl
Does anyone have a chart explaining what "Service 1", "Service 2", "Service 3" etc. mean on a W213 E400D?
One more question: what service number indicates that the V-belt needs to be replaced?
Reactions:zuzuhe
On the Mercedes-Benz W213 (including the E400d), the maintenance system uses "Service A", "Service B", "Service C", etc. instead of numerical service levels like "Service 1", "Service 2", etc. Here's a breakdown of these Mercedes services:
  1. Service A: A basic service that typically includes an oil and filter change, as well as basic checks of the vehicle’s systems.
  2. Service B: Includes everything in "Service A", but with additional checks that may include a brake fluid change, cabin filter replacement, and a more detailed general vehicle check.
  3. Service C onwards: More advanced services may include more complex servicing such as spark plug replacement, transmission service, differential fluid change, etc. Each step represents an additional level of service, so for example, "Service D" would be more comprehensive than "Service C".
If you see codes "Service 1", "Service 2", this may be a regional or dealer interpretation of these standard Mercedes services. It is best to consult your Mercedes dealer or consult your owner's manual for detailed information on the maintenance requirements for each service.
For Mercedes-Benz W213 (E-Class) including E400d, the V-belt is usually replaced at approximately 70,000 to 100,000 km or at specific service intervals such as D or E service, depending on vehicle usage and environmental factors. Mercedes does not provide a standard "service number" for the V-belt alone in its global service codes, as replacement is usually based on mileage and inspection rather than a set service code.
However, during the "Service B" and subsequent higher services (such as C, D, or E), the technician should check the condition of the V-belt. If your mileage is approaching or exceeding 100,000 km or about 5-6 years, it is wise to check the V-belt, even if it is not specifically listed in the current service interval.
Reactions:lcsvcruz and nano5849
I'm also adding a list of service codes that I saved just in case it helps someone.
Service 1: Minor basic service (Service A)
Service 2: Major basic service (Service B)
Service 3: Engine oil + filter
Service 4: Brake fluid
Service 5: Combination filter
Service 6: Dust filter (included in Service B)
Service 7: Activated charcoal filter
Service 8: Air filter
Service 9: Tilting/Sliding roof
Service 10: Panoramic sliding roof
Service 11: Fuel filter
Service 12: Spark plugs
Service 13: Coolant
Service 14: Main coolant circuit
Service 15: Trailer hitch
Service 16: Parking brake
Service 17: Emergency call system
Service 18: Brake algorithm
Service 19: Diesel particulate filter
Service 20: Automatic transmission oil and filter
Reactions:Ollikola, Mersovod, benz1288 and 4 others
And my updates and help.
Service 8: Replace the air filter or, in some cases, the rear differential oil (see service sheet)
Service 24: Water pump/timing belt replacement
Reactions:lcsvcruz
And workshop codes for ASSYST PLUS.
A - 505 - Service 1, 3
A1 - D0D - Service 1, 3, 4
A3 - 550A - Service 1, 3, 8, 11
A4 - D50J - Service 1, 3, 8, 10, 11
A5 - 3D0G - Service 1, 3, 4, 8, 12
A6 - DD0S - Service 1, 3, 4, 8, 10, 11
A7 - G50M - Service 1, 3, 20
A8 - Q50V - Service 1, 3, 10, 20
A9 - GD0V - Service 1, 3, 4, 20
A0 - 850D - Service 1, 3, 10
AC - QD051 - Service 1, 3, 4, 10, 20
AF - KD001 - Service 1, 3, 4, 8, 12, 20
AH - 801050E - Service 1, 3, 13, 24
AG - VD0A1 - Service 1, 3, 4, 8, 10, 11, 20
AK - 10D0E - Service 1, 3, 13
- MMOA1 - Service 1, 3, 4, 6, 8, 11
B - 606 - Service 2, 3
B - N0N - Service 2, 3, 15
B1 - E0E - Service 2, 3, 4
B2 - 8E0N - Service 2, 3, 4, 10
B3 - 560B - Service 2, 3, 8, 11
B4 - B60H - Service 2, 3, 8, 10, 11
B5 - 5E0K - Service 2, 3, 4, 8, 11
B5 - 3E0H - Service 2, 3, 4, 8, 12
B6 - DE0T - Service 2, 3, 4, 8, 10, 11
B7 - G60N - Service 2, 3, 20
B8 - Q60W - Service 2, 3, 10, 20
B9 - GE0W - Service 2, 3, 4, 20
B0 - 1607 - Service 2, 3, 8
B0 - 960F - Service 2, 3, 8, 10 (on a GL63)
BD - M60T - Service 2, 3, 8, 11, 20
BE - V6031 - Service 2, 3, 8, 10, 11, 20
BK - 10E0F - Service 2, 3, 4, 13
BS - 1Q60X - Service 2, 3, 10, 13, 20
Check the workshop code in your car (service menu), take the service number from the Delon list above and find out what to do.
Reactions:Mersovod, benz1288, Delon and 1 other person
It should be the same for all models, right?
If you get the exact workshop code, then yes.
Reactions:Baxarn
Additionally, these numbers essentially tell you what the codes in ASSYST PLUS mean.
If you contact ASSYST PLUS to confirm service, these numbers will be listed there.
I was getting Service A3 when the car started. I didn't know what Service A3 was. After that I went to ASSYST PLUS and wanted to confirm the service and it showed Service 1/3/8/12 and looking at the list it was basically Service A3. I just need to change the spark plugs :D
Mercedes does not publicly provide an official chart explaining the exact differences between Service 1, Service 2, Service 3, etc., as they vary based on mileage, timing, and additional maintenance tasks required. However, in general:
Service 1 is a basic oil change and inspection.
Service 2 includes Service 1 + additional checks (e.g. brake fluid, air filters).
Service 3 and beyond are more comprehensive services depending on mileage and wear.
As for V-belt (timing belt) replacement, this is usually part of a major service, often around 100,000–150,000 km (60,000–90,000 miles), but the exact number of services may vary. It is best to check Xentry or your digital service report to find out the specific replacement schedule for your vehicle.
theRogue
  • theRogue
itsme
  • figuwx
figuwx
  • figuwx
figuwx
