Who Can Help Me to Activate the AMG Menu W204?
  • Thread starterMARCOSOFT
MARCOSOFT
Can anyone help me activate the AMG menu on my W204?
Reactions:renato.301
I can, you just need Openport 2.
Reactions:revo7ution
Ok, I have Openport 2.
Please continue the discussion in private messages through the private conversation system.
Reactions:MARCOSOFT
To activate the AMG menu you have two options: change the EEPROM address or use a tool like MBTools. I experimented with some clusters by adjusting the EEPROM address.
For the W211 model, offset 000210 can be changed by changing bytes 212 and 213 to FF FF, which is equivalent to 50 28.
For a color display like the W204, at offset 0001D0, simply change the first byte from FC to FF. Be careful though, as this modification may result in the CNG indicator appearing on the instrument cluster instead of the ESP indicator.
Reactions:Bruto
Do you make these settings in Vediamo, right?
Yes, you can use Vediamo, but you will need to buy the Seed Key Calculator or find someone on the forum who can do the calculation for you.
Or another method using an EEPROM programmer and a disassembled cluster.
Reactions:vautex
lirimen
  • lirimen
lirimen
lirimen
  • 47009502
carman777
Karahan
  • Karahan
Karahan
Karahan
