Moderator
Staff member
Developer
- Solutions
- 17
- 5,579
XENTRY Special Functions Keygen
Special settings or functions password generator/keygen for XENTRY.
Updated with all features 10.10.2023 to v1.2
- Old algorithm form v12.2013 to v12.2019
- New algorithm from v03.2020 to v09.2024 and v12.2024 without AddOns
Switching between algorithms can be done by ticking "New".
- (1) Air conditioning/ACC - Special settings
- (2) Sound - ESS/EOC activation/deactivation
- (3) Airbag/SRS - Special settings
- (4) Engine - Regeneration DPF, flashing
- (5) FDOK - Blocked vehicles
- (6) CDI2 - Adjustment of EGR
- (7) KI/IC - Belt warning
- (8) MBConnect - Deactivation
- (9) Offline activation
- (10) EZS/FBS4 - Offline locking of key or key track
- (11) FDOK - Unlock documentation
- (12) SAM_450 - Programming of vehicle equipment
- (13) GS - Special parameterization
- (14) KI/IC - DnW Smart KI_451
- (15) SAMF - Chassis
- (16) mbrace - Current VIN writing for ECU
- (17) MoTelDiS - Logging
- (18) CLCS - Manual calibration of level sensors on customer request
- (19) INS - Operating hours counter writing
- (20) Immobilizer code model range 415, 453
- (21) TSG - Adjustment of window lifters 212
- (22) Codings for Citan
- (23) MoTelDiS - Telephone cradle recover-flashing
- (24) EZS - Teach-in of new car keys 451/454
- (25) Powerline Gateway - Vehicle homepage write certificate
- (26) NAG - Kueb lockup
- (27) MCM - EOL values
- (28) SIM4CNG Transporter - Deactivation of low pressure shut-off valve
- (29) Airbag/SRS - Roadside Assistance Vehicle
- (30) CRCM207 - CRCM Topcontrol
- (31) SGR - System information
- (32) KI/IC - 120kmh warning deactivation for Gulf countries
- (33) KI/IC - Deactivating of the mirrors functions
- (34) TGW4 - HU internal logfile creations
- (35) RWTS - Desensitize tailgate closure S211
- (36) ABR/ESP - VIN resetting
- (37) ABR/ESP - VIN manual writing
- (38) CDI4 - Adjustment of EGR
- (39) KI/IC - Activation of mirror parking position (230,211,203M)
- (40) KI/IC - USA: Fuel sensor seat detection fix (203 for MOPF)
- (41) ECallRus - VIN writing
- (42) Stationary heater/STH - Special settings
- (43) ABR/ESP - Events, EEPROM values
- (44) AWF/SG-AWF - Object recognition
- (45) Electric Power Steering - Correction of function
- (46) AWF - Event data
- (47) Airbag/SRS - System information
- (48) TGW4 - Video-AUX activation for special protection vehicles
- (49) SAMF - Outdoor light function
- (50) SAMF - Interior light function
- (51) KI/IC - Adaptation maintenance interval
- (52) EZS Transporter - Coding according to the factory specification
- (53) Engines Transporter - Coding according to the manufacturer
- (54) KI/IC Transporter - Coding according to the factory specification
- (55) ZGW - Establish delivery status.
- (56) EGS Transporter - Rework CDB converter
- (57) Airbag/SRS Transporter - Error 9077 fix
- (58) Airbag/SRS Transporter - Security components deactivation
- (59) Engines Transporter - Low idle Speed
- (60) EZS Transporter - ESP 5.7 to ESP 8.1 conversion
- (61) ABR/ESP Transporter - Deactivation of system components (BR 901-905 only)
- (62) ASSYST PLUS - Re-arrange service memory
- (63) SAMR - EDW-Alarm
- (64) Powertrain Gateway - Extended
- (65) OBL22kW - Vehicle-Homepage update
- (66) BMS - Close training via diagnostics
- (67) CTT-ECUs - CTT Special parameterization
- (68) COM - GMS-Antenna resistance
- (69) Seats - Special settings
- (70) mbrace - Login details for cellular network
- (71) Manoeuvring - Special calibration and other special measures
- (72) KI/IC - Reset to the global encodings
- (73) TP5 - TP5 Bras default settings
- (74) Engine - Fault memory
- (75) Edison - Programming
- (76) TP - FleetBoard support
- (77) Airbag/SRS - EDR
- (78) SAR - System information
- (79) NAG - Adaptation data
- (80) NAG - EEPROM values
- (81) TP5 - TP5 Bras SIM card removing
- (82) GS2 - Programming
- (83) Powertrain Gateway - Force flashing
- (84) ACM - Regeneration speed threshold DPF
- (85) HERMES - Logging
- (86) Tailgate control - PTCM213
- (87) Audio/COMAND - HU Transporter
- (88) TV - LTE support coding
- (89) MPC - Multifunction camera writing values
- (90) MS - Reset total times
- (91) TCM - Extended diagnosis
- (92) WPRA167 - Wiper function
- (93) INS - BRA special functions
- (94) SACHA453 - Connector type configuration
- (95) Gateway and Engine - change VIN
- (96) CRCM232 - Dachsystem engines
- (97) Airbag - Crash memory trucks
- (98) Airbag - EDR UNECE
- (99) Air conditioning - Flushing the refrigerant circuit
- (100) RET - Gear ratio
- (101) TCU - Flash compromised TCU
Just launch and use.
NOTE: This keygen is useless for my commercial activation as the global bypass has been implanted for all vehicles in XENTRY since v03.2018 which greatly simplifies the workflow.
OS: MS Windows XP and above
Installed size: 2.10 MB
XENTRY.Special.Functions.Keygen.v1.2_autogmt.com.rarExternal link · Views: 258
