2014 Toyota Corolla with Intermittent Electrical Problems
  • Thread startermpaavi
Today I was driving and checking the wheel speed sensors. While I was turning and driving slowly, the systems failed twice. It now also has ABS fault code C1201.
  • c1201freeze_045505.pdf
  • DTCdriving_abs_diagnose_on_045457.pdf
It looks like the ABS control unit is faulty.
44540-02430, looks like the part number of the ABS module. Are there any special features when replacing with a used one with the same part number? For example, Mercedes modules are blocked by VIN number.
I have an automatic transmission, can I replace it with a manual one, even if the part number is the same? Or is it a different model, etc.
Solved. The problem was a worn ignition switch. I turn the key, the error appears and disappears.
Reactions:popeye2
