4 button Key coding!
  • Thread startercarman777
carman777
Can I code a new 4 button key using my existing key code for a laguna 3 using the can-clip, thank for any advice in advance (y)
Good evening, no you cannot assign a Laguna III card with the card code and Can Clip.
To make a Laguna III card with Can Clip, you need a Token and access to Renault Net.
You can do this with Renolink.
Autel, Renolink, Delphi if you know your car's pin, needs battery charger on the car and proceed easy procedure have done many times.
Yes Renolink works great also see if you can find the software called PIN EXTRACTOR first.
Yes. I have it. PIN extractor outcode, incode, pin from dump.
No you cannot use CAN-CLIP to program fob keys, only possible with RenoClip (BUDGET around $40 eb*y ) OR HIGH END diag tools like ATUL, Launch, with key prog functionalities... etc
  • mattula
esteta
Szopuu
EduardNN
  • User
brend
brend
