CFF Flash File Tools
  •  Tools Download
  • Thread starterxzenurl
xzenurl
xzenurl
Screenshot_81
Can read Mercedes flash files (CFF) and extract binary segments.
  • CFFFlashFileTools.7z
Reactions:bohrg1, effect, oppeto and 47 others
Hello, I tried this tool and it looks great.
The only thing is that I always have a white screen, but if I click on it correctly, I can import CFF and export segments.
Do you have an idea?
Windows 10 64bit.
Install Visual C+ v14.
Reactions:SW Solution
Is there a tool that converts BIN to CFF?
Reactions:maba41 and User
There is some plugin for WinOLS available to convert BIN to SMR-F.
But no one can say if it is possible to flash a "modded" SMR-F file to your ECU.
The problem is that for the SMR-F file you need to calculate the checksum, if it is not calculated, then DTS Monaco will refuse to write the file.
Reactions:felsch007
So if you calculate the checksum using WinOLS, you can write SMR-F to any CU?
I can't give you a clear answer to this question, but as far as I know, modified CFFs are not written to Vedimo until the name checksum for the CFF is calculated.
Modified CFF/SMR-F have calculated and correct checksums, but are signed, so they cannot be used for flashing with regular control modules.
The device management firmware needs to be patched so that it can accept unsigned firmware files.
I used to have a similar patched CPC_NG needed for AMG tuning.
Reactions:B0bby92 and karone
cbraeburn
  • cbraeburn
chris966
Bruto
Bruto
Bruto
stevejia
penyo_stoyanov
