Coding Used Headlights TO W238/W213 with DTS Monaco 9.02
  • Thread starterwolf38
wolf38
Hi Guys,
I have W238 which required both headlights including the ballast/modules replacing. So I have bought two used headlights including the modules. The headlights are working fine, so I have the DRL, Dipped beam, High beam, Turn signals all working. But I get right dipped beam, left dipped beam and intelligent light system warnings on the dash. (Note: The used headlight are ILS)
The DTC 's are
"Control module for LED driving lamps actuation module is faulty. An incorrect or incompatible configuration was identified"
and
"Control module for LED driving lamps actuation module is faulty. The function or the instruction is faulty."
Another side note the left headlight does the welcome light show when you turn on the ignition but the right one doesn't.
My questions are:
  • I am wondering can I code the headlights using DTS Monaco 9.02? If yes, how can I do this? (Can anybody assist me please?)
  • I have been reading on the net that I would have had to save the coding data from the previous modules and copy them over to the current used ones on the car, is that correct? (But they are faulty.)
  • Is online scn coding the only option?
  • Also how many different ways is there to do this type of coding?
All help will be very much appreciated.
Thank you very much!
Hi What Control unit does your headlights have is it the below?
HLI_FL253
HLI_FR253
Reactions:thebigbadwolf
253 or 247?
Of the units?
Hi Guys,
The units are HLI_FL253 and HLI_FR253. There also coding errors on PXL213_FL and PXL213_FR
I have attached a picture from DTS9.02 for the coding from HLI_FL253, the coding is just 0's for the current coding's, I am guessing that proves that it is not coded right? localmode chris966
Thanks
chris966 localmode
Do you guys know which engineer routines to run after coding the headlight on DTS Monaco?
Thanks
Reactions:Alpmedica and thebigbadwolf
  • papaquito
GIN
Oobals
  • Delon
Delon
