Diagbox 9.150 Free without Activation
  •  Download
  • Thread starterkamelmdk
kamelmdk
kamelmdk
launcher
The program is 100% functional without activation.
Suitable for all PSA Peugeot / Citroen / DS vehicles from 1988 until April 2023.
You will be able to communicate with the following computers:
  • Engine - injection computer (diesel, gasoline, flex-fuel, gas, etc.)
  • Automatic gearbox
  • Intelligent Service Box (BSI)
  • ABS/ESP
  • Airbag
  • Air conditioner
  • Dashboard
  • Comfort systems
  • Power steering
  • Controlled suspension
Main functions:
  • Reading and clearing fault codes
  • Service Indicator Reset: drain/maintenance
  • Real-time data reading (temperature, air flow, etc.)
  • Testing actuators (EGR actuator, throttle actuator, etc.)
  • Brakes with ABS (steering wheel angle sensor, brake pressure sensor, parking brake maintenance)
  • Instruments (maintenance information, maintenance intervals, etc.)
  • Injector coding (only on some car models) / Injector programming
  • EGR valve calibration
  • Regeneration of the FAP diesel particulate filter
  • Reset Adblue, Eolys/cerine calculator
  • Calibration, calibration and self-learning
  • Airbag warning lights, immobilizer
  • Testing and measuring flow, turbocharging, pressure
  • Diagnostics and regeneration of the diesel particulate filter / Checking the Adblue module / Electronic emission control / Checking the lambda probe
  • Setting up a new airbag computer
  • Airbag computer diagnostics
  • Setting up a rain sensor and automatic light switching
  • Activation of Xenon headlights / Activation of rear radar
  • Activating the car radio / CD changer configuration
  • Activating/setting up the alarm
  • Bicycle or trailer hitch configuration
  • Duplicate keys
  • Diagbox 9.150.7z
  • Love
Reactions:jdv91, jeffliu, dubaimaster and 38 others
What cable does this program work on? J2534?
Reactions:whatislove, fromfleet7, halis15 and 3 others
It will work with GODIAG GD101, which is J2534.
Reactions:fromfleet7, halis15, brinka_123 and 4 others
Without activation, does that mean you need to find the activation yourself or is it ready to use?
Does the version work with both Passthru and the PSA interface?
Reactions:fromfleet7, halis15, brinka_123 and 2 others
No activation required.
Works only with Lexia 3.
Reactions:fromfleet7, milanreks and V3lmu
For which operating system?
I have it installed on Windows 10 x64. Defender should be disabled.
Reactions:mateus.caeiro and xuaomi9
Yes. Defender must be disabled.
Has it been tested on new and old PSA cars?
I heard that this version is not very good for older PSA cars.
Reactions:kaurisalkdasjds
This is just an old Diagbox with a homemade database, does not work on new cars (even 2020), does not work with the new interface, I do not recommend.
Reactions:aapjeka and ALEXANDER1
  • J13
john
  • Marketplace
  • Doughy2002
thrwawy111
thrwawy111
