Folding/unfolding the mirror when locking/unlocking E200 W207
  • Thread starterRatherUnknown
RatherUnknown
RatherUnknown
Is there a coding that allows the side mirrors to unfold after unlocking the car automatically?
I have an E200 W207 facelift 2015.
The mirrors fold in automatically when the car is locked. But when you unlock the car, they fold out again after opening the door.
Here is the mirror encoding option from the file CBF DMFL_212
W207 DMFL_212... 2014
Title= ECU DTS Monaco
8.14.016
7.01
15/02/2021
1208
NoOfDomains=9
Title=WDDKK7DF5FF296493
Comment=
VCD_Bandende_Aussenspiegel=0A,0C,10,2F,0F,73,10,3A,09,03,0A,2F,6A,6A,04,0A,FF,13,9C,0F,0F,00
VCD_Bandende_EKS=30,24,30,24,24,62,4B,BC,50,2B,38,2A,2E,08,64,0A,08,1E,32,14,00,46,09,13,00,00,30,14,9E,15,14,00,5C,08,3C,32,0F,54,54,05,32,00,8D,00,61,80,20,20,00,4E,80,21,4C,35,20,2A,2A,40,50,FF,70,40,30,03,0F,CC,44,9A,86,37,47,08,32,8E,58,00,0E,32,32,64,1D,19,E7,5C,36,88,53,F7,36,85,08,96,01,1E,75,0A,0C,0F,40,80,C0,10,0A,02,0F,46,0A,04,3C,C0,32,05,0A,0F,04,77,44,33,22,3C,14,83,22,16,16,14,14,12,28,8C,0A,05,DC,50,3E,64,0C,1E,0A,69,46,32,32,3D,38,82,0C,0D,00,01,09,04,00,00,BE,4B,44,FB
VCD_Bandende_EKS1=42,00,55,10,64
VCD_Bandende_EKS2=08,64,64,A0
VCD_Bandende_EKS3=0A,0F,00,46
VCD_Bandendeprogrammierung_DAG=30,00,00,50
VCD_Konfiguration_DCM=20,00
VCD_Konfiguration_Funktionen=00,04,00,00,F2
VCD_Parameter_Fensterhebermotor_Kontrolle_SCN=30,64,30,26,9D,18,05,46,14,28,8D,61,04
Most likely the problem is something else. They must not fold after automatic unfolding when opened with the key. Only if you do not turn on the ignition after opening the car can they fold back on their own.
Face Lift the same.
Also check the encoding in CGW.
Reactions:RatherUnknown
- I have performed a software flash upgrade for DMFL_212 and DMFR_212. I thought I would get additional settings to unlock it
- Coding saved before flashing
- After completion, Band end EKS is set to invalid, although it should be something and that which is green cannot be changed due to error nrc = 33 security access denied
The windows no longer close completely, I get a headache :)
Update:
DMFL_212 & DMFR_212 Security Access
2E 01FF Start Kodierung Schreiben
Granted access in case someone is facing the problem :)
Reactions:mic4130 and Mersovod
If your windows don't close all the way chances are they need to be recalibrated. Mercedes has a teaching procedure meaning you basically have to teach the windows how far to go up to close and the same when opening. This is in your manual more then likely.
  • cablondon
  • Vediamo
cablondon
Filip
Oobals
