Ford Transit Motorhome Dashboard
  • Thread starter4493ph
4493ph
I have a Ford Transit motorhome (Roller Team 696). The car is from 2016, but the mileage is very low - 12,200. While I was driving in the rain with the wipers on intermittent mode, I decided to adjust the intermittent speed. After a few seconds, the entire display on the dashboard began to flash as if it was completely losing power. No headlights, tachometer or speedometer. However, the engine was still running and the indicators were working without a display on the instrument panel. I stopped and turned it off for just a few seconds, but it didn't solve anything. So I decided to turn it off and leave it for 30 minutes. After that, everything returned to normal. Does anyone have any suggestions?
It appears there's a software glitch in one of the modules. Using FJDS or FDRS, you can check for software updates that might resolve the issue.
I'd check to see if the top housing of the module is wet - water often leaks through it. This could affect the operation of the instrument cluster.
Reactions:brend
At first it doesn't work, then everything is fine. Software can't do this, 100% sure!
The key words are rain and water. You need to look for moisture in the blocks or damp contacts.
sothonnop
  • sothonnop
evgenijj
rudykamo
rudykamo
rudykamo
  • User
boonyen
