HHTWin with SM2Pro
  • Thread starternemiro
nemiro
I'm trying to get SM2Pro to work with HHTWin. SM2Pro currently works with Xentry and DAS for CAN and K-line, but when DAS tries to run HHTWin it hangs on the "Diagnostic multiplexer is being Initialized. Please wait..." screen. Has anyone managed to get this to run? Machine is Windows 10 x64.
By the way, yes, I know this is an old thing. I just want to get rid of the C4 (which I have) and build a much more portable diagnostic system.
  • P
    Given by peroogi
Not ALL K-lines work with Scanmatik, try a 24v truck K-line and see how it goes. HHTWin will never work with anything other than Mercedes-Benz original hardware, C3, C4, etc.
Hi mate, Scanmatik does not support the protocol that HHTWin uses, let alone the new K-line/DAS cars/trucks, since Mercedes-Benz has not given the rights/open source to the Scanmatik team, I recommend sticking with C4.
I have a DAS that works with SM2Pro for all other K-line devices, including those on separate OBD2 port pins. Also Vediamo works with them on K-line. Just not HHTWin. I have a C4. Want to build this more portable system.
Reactions:nemiro
  • jeff.n.doe
  • nemiro
nemiro
