Why not tackle the real problem, like finding out the headlight fault code?
If the headlights are working properly, first check what exactly is causing it. It may be a minor issue that can be fixed without coding the panel.
Could you please post a screenshot of the fault code so we can get specific information.
Recently I repaired a W213 headlight, there was a fan malfunction in the right headlight, but it was not related to the fan, but it turned out that the problem was in the headlight module, water got into it.
Even if the lighting is working properly, unstable voltage fluctuations are possible. I recommend checking other error codes related to the electronic system and then reset the error code.
