How to Disable the ECO Start/Stop Function on the W213?
  • Thread startermacbogdan
In your case, it's best to use the original Vediamo with right Files. DTS is newer, but it only lasted a short time and has not been used in development for a long time. However, those module files (SMR-D, CBS, VSB) are written for Vediamo for compatibility reasons. Most serious developers work exclusively in Vediamo.
When you connect the module, you will find an option for unlocking the module at the top. Click it once, and it will allow you to unlock the module for about 3-5 minutes (it closes automatically again). After that, look on YouTube; there are many examples of doing a Last Mode operation, as mentioned above. Last Mode means the last operation remembered. It's not a classic solution like Start/Stop OFF, but it works. The only negative is that the driver has to press the Start/Stop button once.
When you have done that option, click on Coding and make sure to use the "Hardware Reset" command at the top. That's all.
  • auk
keystone
  • jongdu
aammjj31
Dekkaaa
Dekkaaa
