MB EQC 400 Change Country
  • Thread starterMICH-CY
MICH-CY
Donator
I recently imported a MB EQC 400 (N 293, first registration: 09/2021) from Japan to Cyprus. Unfortunately, I can't change the country and time in MBUX. Only the language had to be changed from Japanese to English.
I have a XENTRY 12/2024 diagnostic tablet and a C6/Super MB PRO M6 DOIP multiplexer.
I used this to try to switch the relevant domains from Japan to ECE in the HU6 ECU (HU6_High_FreshUp3_4) using DTS Monaco 9.02 as described in Delon 's "IC177_unlock_and_save_guide.pdf". The ignition switch ECU is called EZS213 (EZS213_Rel_21).
It just doesn't work and I don't get an error message. I was able to do everything as described in "IC177_unlock_and_save_guide.pdf" except for the step to open the security for EZS213 because there is no "Security access Level B" line to click on under "Generic Jobs".
Can anyone help me?
Reactions:tttt
FYI, here are the domains I would like to change in the HU6 ECU:
Main Write -> Language: English (UK)
Main Write -> System Language Sets: ECE
TV Country Setting Write -> Country Code: EU-East 2
Time and Date Write -> Automatic Timezone Recognition: on
On Off Behaviour Write -> Shutdown Timer: on
On Off Behaviour Write -> UserOff-Style: clock view
On Off Behaviour Write -> OnOffHKDunja: on
Navigation Write -> Navigation Region: ECE
Reactions:Hzr
If the "Security access Level B" option is missing, it may be related to the firmware version of your ECU. Some firmware versions may not reflect this option in the diagnostic tool. In some cases, other settings must be correct before additional options will appear.
Reactions:tttt
Have you synced with volatile memory in HU6?
  • XENTRY Diagnostics
13K
