Mercedes Actros MP4 - Frequent DPF Regeneration AdBlue Error (0C1112)
  • Thread starterJakubMarshall
I have the same errors (0C1112 + 0C1101) on my Mercedes-Benz Atego MP4. Regeneration occurs every day (approximately every 400 km).
Has anyone found a solution to this problem?
Has anyone checked the temperature of both NOX sensors during regeneration?
What's surprising is that when the engine is cold, both NOX sensors show around 93-94 degrees, which is normal. The front NOX sensor shows a temperature status of "reached." After the truck runs in regeneration mode for about 5 minutes, and the front NOX sensor temperature exceeds 150-200 degrees, it suddenly shows 0 degrees, and the temperature status of "reached" changes to "unreached".
Could this be the problem?
  • WhatsApp Video 2026-04-07 at 16.54.06.mp4
    7.8 MB
Have you solved your problem? What NOX sensors do you use? Genuine or non genuine?
  • Ollikola
Ollikola
  • asdadad
RicoChef
RicoChef
