Mercedes W163 and W220
  • Thread startervirtualmerc
virtualmerc
I have two Mercedes W163 1999 and W220 2003. I have not seen these models on the forum. I am new to the forum and just starting to diagnose and program cars. I want to use Xentry to diagnose, repair and reprogram them, but I am completely confused. What cables and multiplexers work with them? Openport, C3, C4?
  • W
    Given by waxxx
Xentry is not a diagnostic program for "old" cars. In Xentry you can select them, but Xentry will switch to the DAS program. Older cars use HHT. You will need the appropriate C3 or C4 devices, the appropriate cable set, etc.
I would use a C4 or OBD2 cable.
Thanks for the answers. I will look for software for C4 and DAS. I am currently using Launch X431, it can do a lot of things, but I want to go deeper.
I also saw a cable compatible with Toyota. Is this true?
Try to check in advance whether the OBD buses fit the connector.
clickbait
  • clickbait
cjz
  • ricooryin357
ricooryin357
  • johnb
bohrg1
