Mercedes W219 Cluster Changing Temp Units
  • Thread startertonynz
tonynz
I did a little research on changing the Fahrenheit to Celsius scale on my cluster, but there is no option in the cluster settings to change this option.
Will I be able to do this through DAS?
To adjust the instrument cluster from Fahrenheit to Celsius, it is best to use Vediamo or DTS Monaco.
Start DAS -> Select your car->Instrument Cluster -> Control Unit Adaptations -> Current Menu Setting -> Memory (1,2,3) Display unit for outside temperature -> set "Celsius" -> F3 -> F5 -> F3.
You may need to perform a full instrument cluster reset or remove/install the battery terminal.
Reactions:tonynz
What market was your car intended for? It's surprising you couldn't do it manually from the car.
Dyostin23
Dyostin23
Dyostin23
percooo
  • percooo
wojciech300
jatoi92
  • jatoi92
cmkfarooque
