ODIS-E Installation Error
  • Thread starterbohrg1
bohrg1
Can anyone help me? I downloaded ODIS-E 17.01 from here and am trying to install it on a laptop with Windows 11 Pro N version 21H2. Unfortunately, without success. I already have ODIS-S 23.01 on the same laptop. The program was installed without any problems. I read that you can run ODIS-S and ODIS-E simultaneously on one laptop. I took a screenshot of the error message.
  • B
    Given by bohrg1
Thanks everyone, I have already tried these tips. The only thing that really helped me was what I described above. Uninstall the VW ODIS 6154 driver in VX Manager and then you can install both ODIS programs without any error message. Then install the VW ODIS 6154 driver again using VX Manager and you are done.
So you have some files left from the old version, you need to delete everything using the Revo Uninstaller program. Or something is missing in the drivers. But most likely it is because of the old version.
I did not install the old version of ODIS-E before this one. I have ODIS-S 23.01 and I wanted to install ODIS-E 17.01, as I wrote above. ODIS-S 23.01 installed without problems.
Or click the Cancel button when the message appears.
Then you can patch and run the software.
The error in installing ODIS, whether S or E, could have occurred after long experiments conducted by me.
And you can install ODIS-S and ODIS-E together on the same partition in both Windows 10 Pro and Windows 11 Pro N version 21H2.
The error occurs when you first install ODIS-S as I did as shown in the installation video. I am also a happy owner of VXDIAG VCX SE DOIP and after installing ODIS-S I called VX Manager and installed VW ODIS 6154 driver. A day later I thought that if you already have ODIS-E, you can install it too. And here it is, the installation error. Numerous pieces of advice, for which I am very grateful, did not help.
Error in the driver installed after installing ODIS-S VW ODIS 6154. Remove it again and then install ODIS-S and ODIS-E together on the same partition. After installing both versions, run VX Manager and install VW ODIS 6154 driver again, then both versions can be used with VXDIAG VCX SE DOIP.
I can't say if this error occurs with other drivers as I haven't tested it, but I can assume it does too.
ODIS-E-install-error-01
You can open Task Manager and stop the installation process, restart your computer, and then continue the installation process normally.
This is normal for some installations after ODIS. Just press "Ctrl+Alt+Delete" and exit the installation process when you get this error. Continue the ODIS-E patch process as usual, everything will work fine (I have had this happen many times).
Reactions:APetrovich
John Heha
  • John Heha
prazcon
prazcon
  • codemotionrs
codemotionrs
V3lmu
  • V3lmu
Lapinpoikaa
