Paddle Shifter
  • Thread starterMSilva
MSilva
I am trying to activate the paddle shifter on my W211 E220CDI 2007. After programming manual mode and paddle shifter, paddle shifter do not work but M mode works.
Does anyone know if I need to code anything else?
For programming everything I use Vediamo.
Have you tried activating "Lenkradtippen" in DAS?
Paddles are on byte 29 and C/S Mode is on byte 30.
Reactions:MasterSc and MSilva
Do the paddle shifters work in other modes, such as C or S?
Reactions:MSilva and biturbo
No. On EGS53 do I need to select byte 30?
On EGS53, byte 29 is also for paddles?
Byte 29 is for the paddle shifters.
You can send me your original code and I will activate it for you.
Reactions:DesertBenz602 and MSilva
Original code:
Code:
69 70 65 35 0F 05 00 03 01 05 0D 1E 32 32 00 09 02 02 05 00 03 01 00 00 02 03 00 24 DB 03 04 0B 00 00 00 00 CB 07 25 02 6B A3
Is it possible to activate M and A modes as well?
Try this:
Code:
69 70 65 35 0F 05 00 03 01 05 0D 1E 32 32 00 09 02 02 05 00 03 01 00 00 02 03 00 3C FB 03 04 0B 00 00 00 00 CB 07 25 02 CB C4
No luck, activation did not occur.
What didn't activate the paddle shifters or M and A modes?
So I turned on the paddle shifters, changing byte 29 to 2C.
bobkammoun
  • bobkammoun
percooo
  • percooo
whoever
  • gibsonlp
Head on Toast
