Renault CLIP v237
  •  Download
Important note: I am trying to connect to a 2018 Renault Zoe.
Could it be that this car requires a token? If so, do older versions of CLIP require a token to connect to the Renault Zoe?
Try an older version of CLIP. It should work fine.
When trying to use CLIP v237 after connecting to the car I get the following: "Connect the token / select the card".
I can click "Try again" or "Cancel".
When I click "Cancel" I get the message: "This vehicle’s MTC is not available. Only the multiplex network test is possible".
Does anyone know why this is happening and how to fix it?
First I need some information.
What car do you work with? Exact make and model?
I have similar issues with version 237, so I reinstalled a FRESH copy of 234 and everything worked fine, it seems that certain info in the database built into the program are missing in version 237.
By the way, will it work with ELM327? I have one with STN2120 chip and some adapters for it. If not, I will do more research and buy the right equipment. Never diagnosed Renault before.
My ELM327 doesn't work with this, I bought a VXDIAG cable to get it working.
Reactions:Lampa2019 and thrwawy111
Thanks, I think I'll have to buy that too. I haven't tested the CLIP software yet, but when I do I'll definitely use VXDIAG. Thanks again, saved me a ton of time! I'll also try the VAG KKL cable and come back to let you know if it works. Oh, and by the way, what year is the car you're testing?
What technical specifications are required to install Renault CLIP v237? I am having trouble installing on my Panasonic CF-C1 laptop with an I5 processor and 8 GB of RAM.
Reactions:Bombel175
I have already solved the problem with the installation on my computer, now the problem is with the subscription required to work with this version.
Here's what the official Renault ASOS website says:
We are suspending the physical token acquisition service until further notice.
  • Nages
unexjourney
7K
14K
carmelof
carmelof
