dizel088
- 71
This is a description of how you can restore a HDD to MBUX.
PREPARATION
1) Check the number of bad sectors on the vehicle using the actual MBUX values.
2) Remove the hard drive from the car.
3) VICTORIA 5/37 must be installed on a computer with Windows 7.
4) For further work you will need an adapter for HDD SATA to USB.
5) Insert the HDD into the adapter and connect to the computer via USB.
WORK WITH VICTORIA
We select our disk in the list and check the smart data, it must match the actual values previously checked in MBUX.
UNLOCK
The new disk is password protected after installation in MBUX in the service tab, select security operations, a window will appear to remove the password for the protected disk, select password type-master, enter 32 spaces in the bottom line (the master password for Toshiba drives) and press unlock drive, if the actions are correct, a message will appear in the command line indicating that the disk is unlocked.
DISC TREATMENT
Select the Test&Repair tab on the top, select the type of impact on bad sectors on the right - remark, and start the procedure.
COMPLETION
As a result, we should receive a message that all bad sectors have been successfully replaced with spare ones.
After this, you can exit the program, disconnect the disk and install it on the car, after installation we update the MBUX software and the navigation version.
PREPARATION
WORK WITH VICTORIA
UNLOCK
DISC TREATMENT
COMPLETION
