VAG EEPROM Programmer v1.19g
  •  Tools Download
  • Thread starterDiagnos11
Diagnos11
vageeprom119g
With this tool you can read VAG EEPROM up to 2007 and make some changes.
You will need a "K-line adapter" cable!
  • VAG EEPROM Programmer v1.19g.rar
Reactions:vampy2k5, ALeXXBody, pistahe and 20 others
Here is the updated version of VAG EEPROM Programmer v1.20, I got it somewhere on the net, it works fine.
  • VAG EEPROM Programmer v1.20.rar
Reactions:pistahe, zakaziko88, Laurent and 16 others
This is just a mod version of the original version v1.19g with a larger window and optimized color!
Reactions:szlacis70, h3x4, strykersbane and 1 other person
I've searched and found little on this topic, but can you do all the different operations on a cluster using EEPROM? Specifically, I'm trying to install a B6 S4 cluster into a 2003 A4 and see that most of the resources are disabled.
Reactions:szlacis70 and h3x4
Which K-line adapter works with this software?
VAG KKL adapter, OBDLink EX.
Reactions:fapkat
  • 4493ph
hyacinth
  • GanPower
GanPower
  • smiley99
smiley99
